pickledill
- Nebraska
Looking at the colorados they have a Driver side diff drop, from the pictures I've seen the driveshaft just barely squeezes through the cross-member(If I remember the name right) from my understanding the hummer's "crossmember" is wider, looking at pictures that is.
The 7.6 isn't exactly the strongest differential out there, I plan on doing a T-case swap if a driver side drop is possible here. I have read somewhere that removing the T-case in the h3 will cause the ABS and TCS to fail? I was hoping a 8.25" will fit, maybe even a 9.25" being able to fit a locker or LSD would be nice. I plan on pushing over 600hp. I could do a solid axle swap but I really do not want to cut up or weld the frame. This is a very ambitious idea which will certainly not work more than likely
