Have a 2010 H3 Alpha with a leaky drivers side exhaust manifold, where are these mythical replacement manifolds hidden?? I’ve looked everywhere and GM has discontinued them. Passenger side no problem but drivers side is unobtanium!! HELP!!
I have never seen a broken Alpha Exhaust Manifold. What almost always does happen is one of the bolts fastening the Exhaust Manifold to the head breaks off (possibly more than one can break off) and then the manifold does not seal completely. Easy fixes available for that, no replacement Exhaust Manifold needed.
I’m with Doc on this one.It’s a common issue I’ve repaired several Ls motor exhaust leaks including the aluminum 5.3 that you have. Never came across one that would not seal!!
I highly recommend that you buy ARP bolts for the replacement. Last time they will ever break. This is the part number you need
Here is an example of the easy fixes out there... there are multiple brands and applications. I think this one claims it doesn't fil H3 Alphas, don't ell my 09 that as it has had one for a couple years.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
