Due to unforeseen health circumstances, I am listing my 2006 Hummer H3 for sale, which is a complete frame off restoration and rebuild. It has 22k driveline miles, and receipts from many businesses well in excess of $15,000 for a boxed in frame, complete repaint, complete engine and transmission rebuild (as well as transfer case and front and rear differentials,) complete suspension replacement, and MUCH more. If you have desired and loved the look and capability of a Hummer H3, but were scared of all the frame and engine and transmission problems associated with a used vehicle, be sure to keep reading for the deal of a lifetime. This vehicle has a clean, clear title and an accident free spotless Carfax as pictured.
This Hummer H3 is loaded with electronic true AWD lockers, full power options, and all the standard features of a Hummer H3 including the one touch moonroof and much more. The Engine & Transmission had a Complete Overhaul and rebuild performed by Toms Complete Auto 04-03-2020 @ 136,552 miles for $6367.19. All the other modifications were completed this year (2022) which included:
Mechanical:
Complete Steering Gear
Lower Steering Shaft
Air Injection Valve
Air Pump Check Valve
Oil Change & Tune Up
Suspension / Tires / Brakes / Exhaust:
Front and Rear Laser Alignment
5x New Mastercraft Courser HSX Touring 265/75T16 Tires
5x New TPMS Sensors
New Upper Control Arms
New Shock Absorbers
New Inner & Outer Tie Rods
New Front & Rear Sway Bar Links
New Brake Calipers
New Front & Rear Brake Rotors & Ceramic Pads
New Ball joints (Labor, Toms Complete Automotive, $1000)
Toms Auto Custom Exhaust Resonator Muffler Exhaust System
All Universal Joints
Electric / Interior:
Replaced Shift Interlock Solenoid w/ Updated Module
Interior LED Conversion
Replaced Blower Motor / Resistor / Harness
Frame / Cosmetic / Paint:
New Black/Clear LED Headlight Assemblies
LED Turn Signal / Running Lights
LED Side Markers
New Fog Light Assemblies w/ LED
LED Brake Lights
Exterior LED Conversion
Replaced All Door Handles and Covers
Complete Frame Restoration, Box In, Repair & Undercoat (Brand S Auto, $1800)
Complete Vehicle Custom Repaint - Fine Silver Birch Metallic including Cladding & Bumpers (West Coast Auto Body, $2800)
The receipts for every single item here are listed and verifiable. I planned on keeping this vehicle for the next 10 years. If you are looking for the ultimate, reliable, non-molested or modified Hummer H3 with a cosmetically and mechanically excellent bill of health, look no further. The body has 158k on it, giving the driveline 22k miles, and all the other items listed less than 2k miles. No corners were cut on this build, and it is a joy to drive. All power options work as they should, and there are no trouble or warning lights on the dash. The vehicle is straight and true on the highway without any annoying vibrations, wobbles, or noises all the way up to 90 miles per hour. Bone stock with 180k+ miles these are bringing $10,000 alone. I have over $15,000 in receipts alone for piece of mind. Be sure to jump on this once in a lifetime purchase.
Yes, I can ship all over the country or pick you up from Cleveland Hopkins International in Ohio (CLE) Contact me if interested!
Mechanical:
Air Injection Valve
5x New TPMS Sensors
New Shock Absorbers
New Brake Calipers
LED Side Markers
LED Brake Lights
