Hidden Falls Adventure Park - FullSize Trail Ratings
Never wheelalone. Always have a passenger on level1 & 2 trails and at least one other rig wheeling with you on level 3,4,5& 6 trails. Depending on weather trails may be wet. In wet conditions trails ar not ratable andsome become too difficult to wheel. Inheavy rains do not attempt level 4,5 or 6 trails.
LEVEL 1
Trails arerated for stock 4x4 vehicles. Some offcamber obstacles up to 10%. Low risk of damage to vehicle. No winch required.
LEVEL 2
Trails arerated for slightly modified 4x4 vehicles. Some inclines and descents up to 15%, some off camber. Modifications mayinclude lockers, suspension lift, off road tires large than stock. If yourvehicle has any one of these you will be able to traverse these trails.Slightly higher risk for body damage. No winch required but recommended.
LEVEL 3
Trails arerated for modified 4x4 vehicles. Steepclimbs & descents up to 45%, off camber obstacles. Modifications wouldinclude off road tires larger than stock at least 33”, front or rear locker andupgraded suspension and a winch. Moderate risk of body, suspension and drivetrain damage. Moderate risk of roll over
LEVEL 4
Trails arefor highly modified 4x4 vehicles. Steep climbs & descents up to 50%, offcamber. Must have at least 35” tires, front and rear lockers, upgradedsuspension and winch. High risk of body, suspension and drive train damage.High Risk of Roll Over.
LEVEL 5
For extremelymodified 4x4 vehicles. Steep climbs & descents up to 60% in some case, offcamber. Must have at least 38” tires, front and rear lockers, upgradedsuspension and winch. Recommend havingfront dig, V6 or V8 engine. High Risk of Rollover
LEVEL 6 CURRENTLY CLOSED – DANGEROUSDUE TO WATER DEPTH
For extremelymodified rock crawlers or buggies. climbs & descents exceed 60%, offcamber. Very High Risk of Roll Over
We have onelevel 6 trail at Hidden Falls. It’s called Keystone Canyon. Although this trail is short it has the mostextreme or difficult obstacle, an 8 foot high rock wall. In the late summer therock wall is dry but may be very wet at other times.
Do not attempt this trail by yourself. Please make sure you have full lockers atleast 39” tires, winch and another rig wheeling with you. There is a 95% chance that you will incurbody, suspension or drive train damage on this trail. There is an exit to the right of the obstaclein case you decide to bypass the obstacle
