ALPHA conversion!
H3 Jimmie
White Mtns, AZ
Alright, I'm fed up already. I have 06 H3 with the inline 5cyl. (POS) that Chevy should have never put in this Hummer!! I've tinkered with it, rebuilt it (that lasted 2 yrs) had it rebuilt again - and the engine blew anyway. It's gone and I don't want to spend another penny on it.
I'm going V8. Does anybody know who will do the conversion? Is it easy enough that it could be done without too much hassle. And should I put in a new 5.3L or just go right to an LS3?
Concerns I have are mostly electrical. I'm sure I can find the V8 engine mounts and mechanically install the V8. So can I buy an Alpha wiring harness and ECM and slap in a new 5.3L and everything work???? Or is there some trick?
Any and all comments are welcome.
There are 4 build threads here, very informative. I suggest you check them out, humvee used my 5.3 to do his conversion and he documented everyrhing needed and cost on the first post. You dont need to do what he did with buying new parts, but keep in mind there are some H3 alpha specific parts needed to make life simple.
As for the wiring, it depends on what you start with and what engine you use. The 08+ H3s have an e67 ecu that works pretty nicely with the gen IV LS engines (58x reluctor). The prior 06/07 use a different ecu and Im not sure what works, but there was a guy here who did a SBC who currently is transferring his H3 bidy to a tahoe frame.
Keep in mind its much more cost and time effective to swap to an alpha and build up from there
GL
Can't blame you for wanting to go V8, but I'm surprised by the bad luck you've had with the 5-cyl. The Atlas engine is a very high-tech DOHC little engine. Mine has been reliable as heck. I've seen quite a few used H3's with real high mileage listed on fb and craigslist. The 06's unfortunately were weaker, but the 3.7 seems just fine to me for daily use, and the trail use I've done.
The only way I'd put a rebuilt I-5 in mine is if I rebuilt it myself. Too many of these rebuilders cut corners or their guys overlook the simplist of details (don't get me started!!). And there's no way a customer knows what has and hasn't been done. A buddy of mine juuust went through that with a rebuilt Audi engine he bought from a 'supposed' major rebilder (the engine-master's guy). He was going to re-do his and thought, "Welllll, maybe an Audi is best left to that rebuilder." What a crock. There were so many problems he had to remove the engine and re-do a lot of things on it because the oil pressure was low. A lot of things doesn't look like they replaced. He's have been better off with what he had! Thats probably what happened in your case. This same guy competes at Engine Masters every year (Ford V8's) is very intrigued by the Atlas engines (and he's a Ford guy!). He's looked them over pretty well, says there's probably waayy untapped power in one of them with the right mods. Which might be another option for you to consider as a cheaper power upgrade. Then you don't have the weight penalty of a V8 either.
I wonder how easy it is to put a I-6 atlas in a H3 (from like a Blazer, pickup)?
That said, you can't beat a V8. Lot of these smaller engine cars that advertise high HP, you have to wait till the transmission downshifts 3x and the engine spools up to 5,500 RPM to get your power. They still feel 'doggy' in many cases. We have a Jeep G/C with the high-output 4.7 in it. It's lighter than the H3. It moves the Jeep around effortlessly. You blip the throttle and it snaps yer head back some. It's my kid's car now. When she was learning to drive, she'd come home and talk about the gutless Driver's Education cars and how going up a hill she'd put the pedal to the floor and it wouldn't go. She once said to the instructor, "There's something wrong with this car, it just won't hardly go up the hill." ha ha. She was used to her Jeep passing anything on the road and not having to down-shift to do so! Kind of a funny story there.
Good luck on your build. Can't wait to see how it goes.
Guerrero
Spain
Totally agree with you about i5s Atlas engine!
Its an amazing and super reliable engine itself (if well take care of it of course, that equals to periodically cleaning throttle body, iridium spark plugs, clean maf sensor and change Oil with good synthetic using UPF-61R oil filter and good air filters aswell).
And what your buddy suspects...is a total reality! The 3.5 and 3.7 hidden a lot of power that is reduced from factory....especially the 3.7 (its a 3.5 with more bore and lot of head work, better flow head and valves)
With proper mods, I achieve my previous 3.5 automatic, to do the 0 to 60 mph in 9.3 seconds. That is using 285 75 R16 ko2 tyres (33 inch). With the next mods: Volant cai, muffler deleted, Orion headers (best by far), Supermodulation ported throttle body+supersparkz, Iridium acdelco plugs, EFAN conversion, 5w30 synthetic oil, and of course an amazing PCM of NC that they revised multiples times with datalogs to achieve the best.
A friend here have a 2008 Hummer H3 3.7 auto with 285 75 R16 ko2 too, achieves 0 to 60 mph in 8.9 seconds...that is with same mods than mine, except Headers, efan conversion, and Airdoc intake (not volant, but I prefer Airdoc intake over Volant by far).
That same H3 is soon going to receive a set of Orion Headers, efan and Pcm retune by pcm of Nc...and we are expecting to achieve close to 8.2 seconds from 0 to 60 mph, power close to 290 hp (with headers and efan).
Now I have a 2008 Hummer H3 alpha with 305 70 R16 Toyo MTs, that I already refurbish and tuned. I achieved a 7.7 seconds in 0 to 60 mph, that is with: JBA shorty headers, front cats gutted and rear cats replaced with highflow metallic ones, muffler deleted, EFAN conversion, iridium spark plugs, JET performance throttle body, AFE PRO Dry S filter and another amazing Pcm of Nc Tune that they revised another 4 or 5 times for me to achieve the best from tranny and engine. That acceleration is without intake, I am going to put an Airdoc and do another retune, and maybe I reach 7.5 seconds or lower of acceleration from this beast.
Conclussion:
Alpha is amazing in stock form compared to a i5 3.7, but after putting bolt on mods on both, the 3.7 is way closer than you might think to a bolt on 5.3 v8. Of course...there is no replacement for displacement, and power is not torque. 5.3 v8 brights there, and towing...amazing the difference.
Hope my experience helps here! From Spain with love ;)
H3 Jimmie
White Mtns, AZ
Awesome. thanks for the feedback guys. i appreciate it. I'll let you know how it goes.
tje19d
pnw
Did you ever put an 5.3L in your h3?
I am looking at the 5.3L that came with the Alphas ect.i too have a '06. I am hoping you did and want to share your build and your steps
Read the "New Motor" thread that's pinned to the top of the H3 section. There are likely other similar threads in the Builds section.
zebra
cold & windy
keep in mind this is infinitely easier for the automatic trucks than the stick-shift ones... as in i'm only aware of ONE guy who successfully tuned a 5speed v8 swap H3 (H3T, actually).
The main thing is setting up the PCM for a manual V8 truck which was a thing in silverados.
zebra
cold & windy
2006 was the last year of full-size silverado/sierra with a stick - and the newest they ever had under the hood were Gen3 engines & 0411 PCMs.
09-12 colorado/canyon had the same engines & computers as H3 alphas... but were only automatic (manuals were 2wd 4cylinders).
the only vehicles that ever came with manual transmissions, Gen4 LS engines, and this same E67 computer were the 05-15 cadillac cts-v, 5th gen camaros, and C6 corvettes... none of which ever had a low-range transfer case.
according to the guy who did the manual v8 h3t: the only way to make the electronics and gauges happy behind a transfer case was to build a custom OS.
What did he use to make his own OS?
HP tuners? EFI live?
zebra
cold & windy
ain't sure... i understand the guy might've had an account on here at one point, but the most info i've found regarding his build/process is a handful of youtube & facebook comments. i ain't got an account on either of those (and am unwilling to fork over the mountains of personal data they want to establish them... which is a separate discussion), so i can't follow up on there.
best i gathered was he's in the denver area & somebody from canada helped write the computer using a combination of programming from a corvette (i think) and something 4wd. in the end, he reported all gauges & systems on his H3T (including traction control, cruise control, 4-LOW, stability management, etc) worked just like they did from the factory with the atlas engine.
ps - not confirmed, but maybe the 09 pontiac G8 GXP was likely in that pool of vehicles above but still wouldn't make a difference for this scenario.
My guess is it’s Jamie from Canada. I talk to him quite a bit and can ask him.
Chris it was Jamie. When I had my 06 5 speed I was going to do the swap and talked extensively with him about it but ended up selling truck to my friend. He has it figured out
