Hello all! If you have owned an H3 with a sunroof for any length of time you have most likely experienced some degree of dismay with the poorly designed drainage system. We have had a lot of rain these past three months and I have kept my 2007 garaged to avoid any potential problems. Since the weather has become much dryer here recently I decided to take advantage of that fact and do the proverbial drain tube and firewall grommet modification, ie; clearing the tubes and then drilling out the cross hairs inside the rubber grommets and replace. OK, so I remove the side panels to gain access and just like so many U-Tube videos I locate the grommets. But wait! I have no drain tubes going into the grommets! How is this possible? I see the tube going down the A pillar but it is nowhere to be seen under the dash and going to the firewall. How is this possible? And just out of curiosity and since I already had everything disassembled, I removed the passenger side grommet just so I could inspect this hated little bugger. To my surprise it was lacking any kind of opening! Nothing! Nodda!! Just a normal looking grommet with absolutely no opening. It was not filled in by a previous owner. It came from the factory this way! Where the cross hair type flaps are supposed to be it was all solid rubber. This was true on the drivers side as well. I have never heard of any factory mods of this kind for the H3 in all my years of reading and ownership! So....where exactly were my drain tubes? I removed the lower plastic kick panels near the floors in the footwells and sure enough the tubes were routed along the A pillar and on down past the dash and door hinges and all the way down to the floor level and then through a hole inside the very bottom of the A pillar forward of the doors. I saw no signs of a grommet. (Thank God!) So....I opened the roof and with my trusty water bottle in hand I did the usual leak check and both left and right side front drains worked beautifully! Has anyone else ran into this improvement on their vehicles? It is a surprisingly neat and professional looking modification and so I think it was done at the factory. Any of you experts out there aware of any such design change from the factory? My H3 is a 2007 base package, inline 5 with all the usual whistles and bells.
