stix
- Orlando, Fl
The BCM on my 08 Alpha is being replaced. A symptom going in for repair was non-functioning rear taillight “fast flash”. I don’t know yet the cause of BCM failure but the web MD of forums has be a bit concerned.
I think I have narrowed to two likely culprits
1) Water damage from sunroof drain clog
2) Aftermarket LEDs (interior and rear) without load resistor (remain installed in vehicle)
Is there any way to determine the cause of the failure of the BCM? I have read that the low voltage LED’s can throw enough codes that they can permanently disable the BCM and can certainly understand that electronics don’t much care for water.
Any feedback is greatly appreciated.
Cheers!
Cheers!
