H3 Bolt pattern
tgomes78
Mendon
So can I put Chevy wheels on my h3... really didn't understand all of that
Happy Hummer
Wisconsin
OEM 16"
Width: 7.5"
Wheel Backspacing: 5.84"
Wheel Bore: 101.6mm
Bolt Pattern: 6x5.5" / 6x139.7mm
As stated above.... Center bore is important.
tgomes78
Mendon
The rims are off a 2000 Silverado... I can still use the tires but I didn't know if anybody knew if the wheels were interchangeable since both trucks are 4x4 gm products
You need to post the specs of the rim that your are wanting to fit...
tgomes78
Mendon
I looked up the specs and the bolt pattern is the same but the center bore is smaller on the rims so they won't work. But fortunately the tires are the size I was looking for so I can have them swapped to the hummer rims. Thanks for everyone's help
