Cajun Tiger Hummer Rancho Build
Cajun_Tiger_Hummer
Lafayette, La
Soa will not give u a rake with the rancho lift...only without the front rancho kit will give u a rake. No one has ever done the 2nd main spring from a 2500 with a rancho pack
Thanks, thats good to know. Could you post a side view of your H3 with the SOA and rancho front? Also what was your center hub to fender measurements with the Rancho lift. I'm at 27-1/4 front and rear right now...i'l need to double check.
Cajun_Tiger_Hummer
Lafayette, La
this is a different bebe mod. you take the main leafspring from a 1 ton chevy and add that to your leafspring pack (IIRC, please verify with Bebe or 06 H3 if you think you might be interested in this mod). SOA is a whole different mod.
Oops, sorry about that, i read your post wrong. Thanks, thats something i can take into consideraton as well.
Cajun_Tiger_Hummer
Lafayette, La
So i had a little bit of time on my hands Saturday morning. blacked out tail lights.jpgblacked out turn signals.jpg
Next up is nfab side steps and purple cranium rear diff cover in blue to match the hummer.
Purple cranium rear diff cover is on order. Dark navy blue with white lettering. I'll post pics once it comes in.
I am expecting a man in a brown suit to drop off my Purple Cranium Diff cover and min now! I ordered mine in White w/ orange vinyl and the skull...
Should be an easy and straight forward install but I'll let you know if there is anything "tricky" about it tomorrow!
Here you are bud!
Sent from my iPad using Tapatalk HD
They forgot to send me the shipping info, they sent it to me right away.... Then USP happened to show up that afternoon!
Super easy install, if you have the tools and have any idea on how to turn a wrench you can install this... Use an alternating patter when tightening the bolts down and your golden. Just be sure to torque things back to spec when your done
If you have any questions at all drop me a line
owlxxx
Tehachapi, CA
Excellent, should be a piece of cake then. Thanks.
