Door keys
jwilson
Columbus Ohio
I know its in here but I cant find it - Why doesn't my door key/Keyhole work ? Or is it just me ?
woodwardsh3
Oakland Co. Mi.
Most people dont use them, And they seize up. Try some PB blaster and let it soak and repeat an then try wiggling and working the key back and forth. all eles fails replace the lock cylinder.
scoreh3
They make a graphite lube spay for locks that works great ! Just make sure you don't use too much and you wipe your key off after the first couple time you use your key in the lock . Looking at the snow I'm going to guess its a little cold there . Try heating up your key before using it just to make sure the locks not frozen inside .
