Thatsgr8
- Avondale Arizona
Need help figuring this one out. Yesterday the wife and I took off to go shopping. Two blocks from house came to a stop sign and the entire truck just shut off. I mean engine dies radio still on. Place in park, try to restart and nothing. Turning the key to run and check engine light is the only light lit on the dash. Turn to start, no response not even a clicking to indicate a weak battery. Turn off and on the ignition, still nothing. Pop the hood, checked the battery cables are good and tight (already replaced battery terminals). Everything is tight. Get back in, turned key back and forth a few times to try to start, nothing and the only light lit on the dash is the check engine. Kept fumbling with the ignition on and off. The stater clicked twice and stopped. This happened three times. Did that a few more times on and off and finally it started up. While it was off I did have dome lights and they did not dim when I tried to start to indicate a dead or weak battery. Even if there was a problem with the battery the alternator keeps the electrical energized so it should not just die when I stopped. I run the ScanGauge II and noticed the electrical was at 14.7 volts when I stopped before it died. Once it started the ScanGauge did show any codes. Where do I start? TIA.
