Garage Goodies for Sale! H2 takeoffs...
Big2dabank
Central Florida
I have ben instructed by my wife to clean out the garage this year, so here is the list of items for sale.....
Hummer Related....
-OEM 4.10 ring and pinion gear for GM 9.25" IFS - $50
-OEM 4.10 ring and pinion gear from GM 9.5" 14 Bolt Semi-Floater -$50
-Open diff for GM 9.25" IFS - $75
Gears and open diff only have 40,000 miles on them and are like new...
-Fabtech Dual Shock Hoops and Upper Control Arm Brackets -SOLD
-Hummer H2 LE Side Steps (4 Steps) - $75 for all 4 - SOLD
-Hummer H2 Roof Cross Bars w/ Key (2 Available) - SOLD
-Hummer H2 Factory Rock Rails (like new condition) - $150
-Delta Aluminum Toolbox, fits snug in the SUT bed, needs new gas shocks and new weatherproofing seals - $50
I am also selling my custom airbag suspension and custom brackets. The goal of this setup was to ride stock height and adjust each corner up down from the cab while on the trail, but I decided to go a different route with this truck... Kit includes..
-Hummer H2 custom Upper Control Arms w/ bag mounts and Moog ball joints
-front upper frame brackets for bags
-rear brackets for bags
-7.25" diameter front and rear airbags - Denominator II style bags 11.5" extended, 2.8" collapse (4 bags, plus 1 spare included), 1/2" NPT
-Manifold Valve assembly to control all 4 corners, 1/2" NPT
-Smartride in cab controller and control module
entire kit $800, plus shipping
Everything is negotiable and shipping is not included on any items, buyer will pay shipping cost.
MessiaH2
Indian Mills, New Jersey
So you got my attention with this airbag suspension kit for some odd reason. well basically because i cant leave anything alone..LOL
I am not knowledgeable enough about the suspension systems to talk with any certainty so I was hoping you could school me on this set up. The first thing i see is that you used the word stock right off the bat and I already have a 6" Fabtech lift with Airbags in the rear. I can not imagine how to get airbags up front...hhmmm
what can you tell me? larry
Big2dabank
Central Florida
It will not make a difference if the rig is lifted or not. The factory upper control arm is replaced with a custom arm that has a flat plate on top to mount the bags, the upper shock mount is removed and replaced with a custom bracket for the upper bag mount, the shock is relocated below the bracket. This allows the truck to sit a ride height on the torsion bars and then when the bags are inflated the front will get several inches of lift.
Big2dabank
Central Florida
Side steps are on hold for the moment. I was educated by a friend that my price was way low for these and on top of that, I received an offer locally for $100...
Here are pics..
Big2dabank
Central Florida
Fabwork was done by airbagit in Arizona. I worked with them on modifying their lowing setup to gain lift instead of drop. I wish I had the time to keep messing around with it, it would have been a neat setup. Truth is I don't have time and it would probably do someone else more good than just sitting in my garage. If anyone is interested, the upper bag mounts requires cutting off the factory shock mount and welding on the new bracket, so needless to say it is not bolt on.
n0useforaname
PA
It's cool. I had AMP research steps on my old rig.. and i"m probably gonna put them on this one. I love the look of no steps, and the useability of the full flat surface. Just wish that price tag would drop some
LoJac963
Surprise, AZ
They are definitely awesome pieces of equipment. I saw them on FYR's rig in person and was definitely impressed. The price however is far too steep for me. I'll stick with my U's.
