Firesquirt
- La Quinta Ca.
My truck comes with the Fan kit installed stock (SA models). I have a Dual electric fan setup, added to the clutch fan. The electrics have 3 settings, off, low and high. The temp gauge never moves about the half-line even during extensive wheeling, and current temps outside are in the 110s (41-43c)
The electric fans are supposedly sold by the company are the same brand as the ones that come stock on SA Hummers (Spal italy) so Im assuming same results.
The OP is talking about the fan on the inside of the engine bay, directly connected to the engine via viscous clutch. ours also has this one with the two fans in the front :wink:. just imagine if we replaced this fan with an electric one as well :giggle:
Ill try taking a better look today! I thought they are electrics since they are the same brand as the pcmforless ones. However the fact the engine temp needle never moves up about halfway (even at 44 degrees Celsius) is starting to worry me! My H3 manual is based on US models, so no reference to any of this and the dealer has no clue about SA models (they didnt know the Alpha comes with dual fans and many other things)
Mine also stays a hair width below half, and with my bullydog I monitor the temps and they heve yet to exceed 100degrees C. so the two electric fans up front with the mechanical fan does its work well![]()
Do they by any chance interfere with the work of the A/C unit? Im getting intermittend A/C issues mentioned in this other thread http://www.hummer4x4offroad.com/forum/showthread.php?5326-Intermittent-A-C-Cooling-Problem and the dealer is unable to figure out whats going on. Hope you may have something for me...
