Hawse fairlead mounting position?
I am mounting my hawse fairlead on my H3 with the hidden winch set up. The fairlead sits horizontal with the center of the winch drum. My question is should the hawse style fairlead sit more inline with the area of the rope wrapping on the drum? This would at least keep the rope from always rubbing on the fairlead. Mounting the fairlead higher on the mount would raise the rope to the top of the drum. What are your thoughts?
The drum gets small quick when you start to unravel your winch line, in the center suits most situations best.
Every mount I have seen has the fairlead centered on the drum. I just figured that with synthetic rope a relative new comer that the idea of taking the center line and shifting it up to reduce the constant stress on the rope would be considered. The first couple of wraps are always used and have the highest angle in relation to the fairlead. That puts the most wear and tear on the most often used portion of the rope. Just a thought.
ABNTROOP
HIPPO
Vancouver, Wa
A winch is designed to bring things to it. It is not designed to move itself. We all use it this way, but it is not made to do this. While this may seem a trivial point, it does make a difference in the way you operate the winch and the method used. It’s especially important when determining if and where to put a pulley block to increase the advantage of the pull. It is also important to realize that the winch “wants” the rope to be spooled in at right angles to the spool face. Its design is such that any angle other than this will reduce the winch’s pulling power and increase stress on the rope. Always rig a straight-line pull to the face of the winch.If you do not—and I am sure we all have ignored this or worked in ignorance—then pay very close attention, because you have changed the physics of the entire rig, as well as the way the winch was designed to work. Direct right angle pulls are ideal for the winch itself, although rarely practical in field. That fair lead should be centered in the drum to help facilitate this though. How much winch line do you have on your drum? Bear in mind, each additional layer reduces the rated pulling capacity. Better to carry a shorter line on the winch and extensions with your gear. Also bear in mind, typically before winching it's better to pull all but ten wraps of your line to use max performance of your winch as well as avoid the friction issues you are concerned with.
ABNTROOP
HIPPO
Vancouver, Wa
You should check your local 4x4 groups as ours up here has classes led by a Warn rep every 6 months or so on basic use to more complex pulls. Very helpful and informative. Helps build a good knowledge base and familiarity with a tool you may not use very often.
