Mostly what I spent my time on was installing my backup camera. I got tired of not being able to see well when backing up, plus I nearly ran over a couple of idiots that stood directly behind the H3 in a parking lot and didn't bother paying attention to the fact that I had started the truck and my reverse lights were on. I literally could not see them and it was only because I swore I saw something out of the corner of my eye that I didn't just back over them both. (One dude was driving one of those electric carts back into the grocery store adn stopped to BS with his friend, right behind me of course).
Here is the camera and monitor I picked up off of Amazon:
Camera:
http://www.amazon.com/gp/product/B00ZWO9MDU
Monitor:
http://www.amazon.com/gp/product/B007SLDF7O
The camera is pretty nice, it is the license plate mount type and this one in particular has a little button in the wart on the cable that changes the image flip as well as if it shows the guidelines or not. It's very versatile. Plus it is a 170 degree field of view which is nearly as wide as you can get I think. Wide enough at any rate.
The monitor is good for the price, though I wish it could sit lower on the mount. I'm probably going to put in another camera higher up in the rear as well as one on the nose of the H3 so that I can use it for getting a better view when wheeling. It has two inputs and will automatically power on the monitor and switch to input 2 when a 12 volt signal is applied to the blue wire (backup signal wire), and it will power back off when the signal is removed. I was happy to figure this out because I was worried I'd have to manually turn on the monitor every time I got in the car. You only have to turn it on if you want to see what's on input 1. One could also have it so that the blue wire is also hooked to the key on power so it just automatically comes on, but then you don't have a way to have it automatically switch when backing up.
So, on to the install.
First, after figuring out where to mount the camera (I decided to put it right over the hitch receiver, nice and protected and I can hook up to trailers a lot easier, I can't remember who it was that did this first on here, but they were my inspiration) I decided to just wire the power for the camera to the backup lights on the driver side. I debated having the camera always be on, but I decided that if I really wanted to do that I would add another camera higher up instead. So after removing the taillight and routing the wires up, I started by removing insulation from the back light wires. I did not cut the wires, I simply removed about 3/4" of insulation as the wires are loose enough that you can fold them over and crimp them:
Crimping on some ferrules to the camera power wires:
Crimped and heat shrink in place:
This stuff is crucial to weatherproof connections:
Liquid tape applied (plastidip basically, I've been using this stuff long before anyone started pouring it all over their cars, I was so confused when I started hearing people talking about plastidipping their cars):
Heat shrink shrunk:
Camera mounted (ignore the extra holes, and the fact that it's actually unlevel, just pretend I did this perfectly the first time...):
Here you can see the little wart that has the button in it and is where the power and video cable split out:
Wrapped the power connector and the video connector in 3M self vulcanizing rubber tape. Not terribly please with how it went on but that is probably because it was below freezing when I did it. That stuff sticks to itself awesome though, you basically get one shot to wrap it, otherwise you're cutting it off and starting over.
The next big issue was figuring out how on earth to get the video cable run to the camera. Someone had suggested elsewhere to run it under the chassis along the frame rail where the chassis harness, which I started to do, but quickly realized getting it past the fuel tank was a bigger PITA than I wanted to deal with. So I started tearing apart the trunk to see if I could find a way in and just run it inside. Couldn't find anything at first, so I turned to the internet and finally found a post on one of the other forums with a graphic of how they routed their wiring. Turns out in the rear of the drivers rear wheel well there is a opening in the body that is pretty easy to access, and leads right into the truck via another opening. Supposedly there is supposed to be a plastic plug in it, but there wasn't one in mine. I will have to add one eventually before mud/water/etc finds it's way in there when I am offroad. Here is a pic showing where the opening is with some wire I was using as a fishing line sticking through it:
The video cable in a split loom passed through the hole, shown from below (power cable is heading off to the left, video cable to the right):
And passing through the holes:
I then routed the video cable the rest of the way under all the trim up to under the dash. It would have been a lot easier if I had just taken the time to unbolt the upper seat belt mounting point on that rear side so that I could fully remove the panels, but I was stupid and did it the super hard way. At this point it was super dark and super cold, so I stopped for the day.
