- Meridian, ID
mine flexes up just fine. :wink:
as I tell my brother....flex is overrated!
Honestly I'm thinking that I could stop down travel with limiters... that seems like a good idea. Uptravel I don't see being an issue... by relocating the t-spring clocking you change the static position, and preload increases as you uptravel, so I don't feel that you're as likely to have issues in that direction. If limiting travel is the issue... that's fine, but needing them to move independently is a whole other beast.
I think that pic is a perfect example of what I'm talking about. if you look at the uptravel on the pass. side, the CV is BARELY above the center point... I don't feel that's going to be any more danger than me driving around with a T-lift. The droop on the other hand... that angle would scare me a bit, kind of confirms that limiter might be a good idea.
Personally I say **** it...Im gonna disconnect and see what happens. Best way to learn is hands on/trial and error. I won't do anything like this on an extreme trail or with H4O because I don't wanna hold people up if I break. Ill take tools and spares in case tragedy strikes and will bring my brother and a tow strap lol. No more tow trucks!
Im sure nothing bad will happen just wanna be prepared for the worst and will report my results. First I need to run the local trails with em on first then disco and run em again...
But remember, at full droop, there is no load on the shaft or diff. The same is true for the steering with the exception of when the drooping wheel is up against a rock and you are trying to turn the wheel into the rock. That can be very hard on steering and typically pretzels a Toyota idler arm with quickness.
Frank
In my old mind using the shocks as a support for suspension was a bad idea, but then I'm not an automotive engineer.
I think some form of limit should do that besides an $80 shock. It is what it is. I have been able to go just about anywhere I want to in my H3 and can only compare any serious offroading to my old 70 sumpthin FJ55 wagon with leaves on all four corners and straight front axle. I will take the H3.
This discussion comes up from time to time and is a good way to share this info.
I don't have exact comparison shots but here is my H3 back with OEM tie rods when I was figuring out some things. The wheel is turned more than the FJ one which changes the tie rod angle but shows tie rod angles and CV. They would have to be turned about the same for a better comparison.
The FJ was mentioned earlier and I got a shot of a friends new one when we worked on the custom winch bumper.
First thing I noticed was how flat the tie rod angles and CV's were. They are using the struts in the front end.
My H3 was turned up to 23.50 or maybe a bit more.
I had to come down after seeing the angles and to fit the BP tie rods I needed to adjust to about 23.5 to have them clear things.
I have been working off and on fitting an overload spring shock on the front as a redundant support like the torsions. I don't want to completely do a coil over just try to use this idea with my other mods. I started using the Bilsteins and sort of have this project on hold for now, as they have temporarily seemed to have helped the short comings of the OEM shocks. When I get time I will get back to it. I have not mentioned it before but want to try it when I find the right combination. Sounds like with all the brain power being spewed out in this thread I would throw that into the mix.
Frank
Like that dirt ramp up the street!
And that is my concern...full droop and spinning...then ur screwed
For what it's worth, I've broken one CV. Going up a sandy hill and rolled back and caught the rear diff on a rock. With the wheels strait and gentle throttle the front dug holes, fully dropped and banm! So, with no weight on the wheel, and not doing anything crazy, the CV gave out when it fully extended. This was with the front end at 23.5.
