I'd like to confirm that when replacing the OEM changer head unit with an aftermarket unit, the OEM Sirius box ("digital rcvr") isn't reconnected via the new (GMOS-4) harness and becomes ballast.
I think you might be right, but you can always stop by a local Best Buy, and they are usually very helpful with that, he wise they sell the connecting harnesses, along with adapters, connectors, and mounting plates along with radios, if you want to install it yourself.
You are correct. The factory Sirius box is proprietary to GM head units. Similar to how some aftermarket units are specific to Clarion or Kenwood for example.
You you could always use a generic vehicel connection kit. Most run through FM radio or auxiliary inputs.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
