WANTED: Thread on installing the factory fog lights and offroad lights.
IndyHummers
Murfreesboro, TN
I know we had them on the old site, this is something I'm considering doing so I'd like to see what all it entails. Those that have either the fogs or off road lights, what do you guys think of them?
Thanks!
Drew
TrailBreaker
Asheville, NC
I just ordered a roof mount offroad light set for my 3T, and plan on putting Rigid 4" LED lights in the holes. They should fit almost exactly, maybe a little trimming. Once the light mount gets here, I will see and be glad to do a quick wirte up.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
I have both the roof and grille mount off road lights. They are not installed yet but I will try and hook up my scanner and post up the install instructions. I also have a scanned PDF copy of the marker light install on my laptop.
j3jackson
Big tires
The Ozarks
I installed oem front mounted off road lights on my 2010 H3T. I don't think I took any pics. The kit came with instructions. Takes about an hour or less.
Ron46
Capt.
NJ
I have both the roof mounted lights and the grille lights, the roof light install was very easy, the worst part was cutting the holes in your roof :wink: Ill post up some pictures of them tonight to show how bright they are. I also have a set of Piaa's on my grille guard which were incredibly easy to instal, it was just running some wires, hooking it up to the battery, and then running a switch.
2007HummerH2
Maine
I think you answered the question about the roof mounted lights that I had.....wanted to know if you had to cut your roof? What is the reasoning? Is it to run the wiring or to help hold it down?
08SolarFlareH3
Super Swampers
Finger Lakes, NY
You don't have to "cut" the roof but you have to drill holes for the rivet nuts used for mounting. The wiring is ran down the A-Pillar molding into the engine bay.
Here are the offroad install instructions from the set I put on my T
