Water in cab
SolidusJ
FT. Carson, CO
Flipped my rear seat to clean up and this is what I see!!!!!! The left rear cornor and not only that every time it rains my driver door always fill up with water. So what do I do to stop all this water??????
Sircode13
Laguna Hills
Park it in a garage lol, I have the same problem with my H1, but that's because the idiot who owned it before me drilled a hole in the roof. To put the coax for the CB radio through :banghead:
Sent from my DROID RAZR using Tapatalk
Solid, do you have a sunroof? Have you checked to see if the sunroof drain tubes are clogged. i don't have one on my T so I don't know where they are but there are 4 in the H3 - 2 on each side, front & rear. I will ckeck my repair manual to see where the rear ones come out on the T, if in fact they do.
SolidusJ
FT. Carson, CO
I don't have a sunroof and with the door seal I blasted with air a few times and still water in the door. You can hear all the water in the door when it rains but the speakeris always dry.
If it can't get through the door seal, then Dan's suggestion below might be the culprit, especially if the water is in the doors.
D
Dennis
There is suppose to be weep holes or drains in the bottom of the doors..cuz, rain or when you wash it will get past the window and down into the door and it's suppose to drain out eventually..Check to see if those are clogged.
