06 H3's Squeakin H3 Build
I hope so too. It is an old customer of mine. They are employee owned and good people. I’ll manage people for the first time, pay bump, all good stuff. It will be a challenge I’m sure and at times I may question, why didn’t I just ride it out at where I’m at but I’ve been frustrated for 3 years, essentially since my current employer bought out the company I worked for.
My current employer seems to just do the opposite of what the customer, consumer and market wants and then arrogantly thinks we are who we are, they have to buy from us….but market share and sales and the layoffs every 6 months dictate the opposite of what they think. It’s a sinking ship, and while my current boss has been nothing but the best, the big picture is a bad one.
I do not jump ship quickly. I try to be loyal. People in my age group have had a ton of employers, constantly jumping it seems. I have essentially had 2 employers. My college job, my post college job and I don’t count the buyout as a change in employer because they bought us, I didn’t change. So I have essentially had 2 employer’s in 15 years, including college jobs, I’d bet most my age are 4-7 employers by now.
Hopefully we'll se you and Squeaky next year. Or I just might have to pay for your services this summer to help with the LS swap.
Time for a bump!
One last mod I did before starting the new job was flattening the track bar.
Roll center went from 28 to 32in
Track bar angle went from 12* at ride height to 2*
Track bar at full droop went from 23* at full droop to 13* at full droop.
It now goes over the upper link instead of below. I can also go back to the old setup if I need to (I doubt it) but I made it so it can still go in the old hole. My only concern is strength. It’s about 7.25in higher than before, lots of leverage!!!! I put 2 braces on it. One from a tube to the top of the mount and the other is a triangle that ties into the lower control arm mount and goes all the way up to the top of the mount.
On off camber stuff it was way sketchier when the driver side was the high side (making the track bar angle steeper) I have read same side track bars aren’t sketchy or jack if the track bar angles are flat. It certainly wasn’t but now it is
And my first day to work in the new DD.
A few weeks in I got a company truck to use during work, to go to work and to go home from work, with that said, the Hummer is still a DD. The last company car didnt have logo's on it and we were able to use it for non-business related things and on weekends (a perk of that job.) This one is logo'd up and for work use only so I better behave while driving it. So yeah, the hummer is being used daily going to the gym, grocery store, etc.
Anyways, a few weeks into the new job I took the full doors off, slapped on the half doors and went wheeling. Here is probably the best pic I have for new track bar leverage testing. It didnt break. Woohoo. Time will tell but I think the bracing I added should hold.
This notch can be a bitch. The guy before me was in a 1st gen bronco on 37s a D44/9in and fell in the notch, it took winching back, wheel hi lifting up, and a rig above to winch him up like a helicopter....we could have just dragged him out but if we didn't do that he would have for sure broke a u joint or kill a ball joint, he was bound up bad.
Went wheeling a couple weeks after that. I’ll give an update, but first, I’ll mention that I take a picture when I hit every 1000 mile mark. When I went through my phone the past few years I hit it every Sept/Oct. indicating 1000 miles a year since it’s always in Sept/oct. I’m 9 miles away to the next 1000 mile mark and it’s only May so I’m definitely way ahead of schedule now that I’m driving it daily.
Anyways, got a good ass kicking again today.
We ran this trail
Machine screw….last time I ran machine screw I didn’t finish it, my buddy in his Toyota on 1 tons and 43in stickies exploded his t case input shaft and we had to get him out on 0 wheel drive.
So, time to finish it. Admittedly, I winched 3 times, and it’s a short trail, so that’s a good ass whooping.
It was 3 rigs, me, a ZJ that’s backhalfed, cut up, pretty light weight for what it is, on 1 tons and 40s, then a Sami buggy that makes everything look easy.
The beginning was all pinchy tight stuff.
First climb I winch. I wish I had a picture of it from yesterday but here is the last time I ran it and where the Toyota broke
Anyways, the ZJ and Sami buggy have suck down winches and fully used them, I’m not convinced I would have gotten it with one but it would have definitely helped, for reference the Toyota in the pic has a 120in wheelbase. I need to make a change on my cooling setup. I never overheated with my current radiator setup, and a single trans cooler, but I recently added a 2nd trans cooler and a PS cooler in front of the rad and it’s blocking flow. Working it on that climb I got up to 256 coolant temps by the time I noticed it was knocking, I’d imagine the oil temp was 270-280+. So that poor engine got a beat on. So I will be moving the coolers to open up flow. At speed it’s fine and before the coolers it was fine but PS system get hot. I’ve been told 250-300* isn’t out of the norm….if that’s true I’m sure I’m blocking flow with a cooler that is heat soaking the fuck out of the radiator. Anyways, I was on the winch.
2nd climb (above) the Sami buggy got but had to work at it for a minute. The ZJ didn’t get it, he winched, and I was so damn close to getting it but my front end got light, I think a suck down would have helped here. You can see all 4 were climbing.
This was the 3rd winch spot, ZJ and Sami buggy got it.
I also noticed I was at 13.5psi. That probably didn’t help but I give myself the award “trail tampon of the day”
Other random pics.
In the end, I drover there at 65 mph, and drove it home at 65 mph.
Tire pressure is a noob mistake on my part.
I think a suckdown would have helped a ton, that is in the works. I have one but it isn’t complete yet, each iteration has failed but integration with my double ended ram will fix that once and for all.
Weight, I ditched some weight on the 2nd climb and I felt a difference. I think I need to look at putting the hummer on another diet.
It was one hell of a day and I have more to work on.
went wheeling with my wife and daughter, easier rock trail and she did great! Then in July I was depressed about my lack of vacation time at the new job had me miss out on the rubicon trip I do annually so I had to get out of the house and stop feeling sorry for myself.
ran death wobble and lone pine. Lone pine I have done like 6 times and every damn time I run it I winch once or twice. I think I’ve gotten all the obstacles on the trail but on any given day, one of the obstacles will have me hook up on the winch so this was the first time I actually ran the entire trail clean. That felt great.
Typical full door to half door shuffle, did it Saturday night, wheeled Sunday, threw the full doors back on Sunday evening and was driving it to the gym in luxury at 5:30am on Monday.
We had lots of flops or near flops. The 2 Toyotas on 37s with us all ended up sideways at some point. This pic wasn’t bad. It was fully over a moment after that.
Random shot of me on the trail. Didn’t get much pics.
The main change I made is cooling. This thing was a champ at cooling, H3s are notorious for cooling issues, but mine hasn’t been that bad. I did UA 2017 in 115-120* heat and that week had rigs pulling over left and right overheating. I never had to, but a post back I talked about hitting 256 coolant temp. I think the giant PS cooler I added caused big heat soak issues. I removed that and mounted a smaller heat sink style one off the coilover mount. I also moved the dual trans coolers to the rear of the H3. Who knows if it’s enough to get the job done for steering or not. I know the old one was a big plate and fin overkill setup but many run these types.
I also wanted to ditch the trans coolers from heat soaking and mount them by the rear bumper under the rig.
I can confidently say coolant temps are much better now with fresh cool (still 90+ ambient) air. The heat soaking seems to be fixed. I also plan on adding an oil cooler.
An H3T friend said his 5.3 ran 200-220 oil temps and his 6.2 runs 220-240 oil temps.
I checked and sure enough I’ll run 230-240+ all day long on oil temps. I wonder if that hurts coolant temps too.
I’d like to mount the oil cooler there and I have a little 4in fan for it. I have trimming to do and cutting off an old suck down winch mount to drop its height.
Anyways, coolant temps are better. PS temps TBD, trans temps need some help. The fan pushing air on the trans cooler isn’t enough. My old trans setup literally couldn’t get hot. It was kickass, this setup holds its on when the TC is locked but can’t keep up when it’s unlocked. So I solved one issue and made another.
Anyways, I just want a 100% duty cycle, romp on it in 100+ and never get hot setup. I’m shocked I made it as long as I did with no PS cooler but going from 40s to 42-43s I’ve been killing pumps since. That’s kind of what started this snowball effect. Then I figured I need an oil cooler so I wanted to add that now
Someone was talking about their windshield with a UA sticker on another forum and I posted on that thread about how it would be catastrophic if my windshield cracked due to my UA sticker....and sure enough, shortly after that, it cracked! Some asshole semi truck driver was barreling around a sweeping corner at 65 mph on a 2 lane road, I had just enough time to say to my passengers, wtf is this guy doing and right when I said that rocks fell off his semi and then 2 hit me at 65 mph coming the other direction 1 hit my windshield and and the other hit my passenger's arm with the half doors on. It cracked the glass so bad a piece of glass hit me in the face. It almost went completely through.
I am having my mom try to create some replica stickers and make them on her cricket (CAD for artsy women?) I asked Christian Hazel but he said he was out of them.
Other then that, the cooling changes for the coolant has been a significant improvement. Going up a grade in 90* heat, with the AC on, the hottest it got was 207*. Normal operating temp is 210* on the LS from what I understand. I am not sure what the highest acceptable temp is on an LS but before I would quickly spike over 210 on something similar to that. With that said, I still haven't installed the oil cooler and on that climb I hit 246* so I definitely need to install that.
The trans cooler holds it's own but isn't as good as what it was before with fresh flowing air through the grille. It has been a trade off, not more heat soaking the radiator and seeing coolant spikes but trans is warmer, I will mess with fans and get that setup better.
I did go wheeling with my brother and his wife and then we took our 2 sisters, our cousin from NY, and her boyfriend. It is always fun to take people who haven't been wheeling and see their reactions. My wife is way to pregnant to go wheeling right now so she stayed home.
Anyways, Trail 1 went well, and trail 2 was kind of a shit show. I am officially done with my steering setup and I am planning on changing my rear shock setup.
Overall, we had a good day, but like my lower control arm mounts on the frame, they hung up too much and change is necessary. I would like to outboard the coilover mounts for more stability and put them through the floor (minimally to keep storage room)
The steering failed, this kind of all started with going to a closer hole on the steering arm. I did this about a year and a half ago....before, the steering was slow, didn't pull angle, but had power. Now it pulls angle, is faster (box is 3.75 turn so its still too slow) and lost power. I was forcing the steering and actually popped a hose off the low pressure side, I always ran high pressure on both sides but when I replaced them for maintenance I was talked into push lock hose and it popped off, after I fixed that it then was leaking out of the adjustment screw which totally loosened up so I figure something internally is fucked. I was going to go with the setup this guy has on his WJ, normal ram assist with a double ended 2.5in ram but after this I want to go with a setup like 4500 race cars at KOH do. remote mount servo to a manual box. The xterra box I have is outside framerail, rearward facing pitman arm. I cant make the pitman arm longer due to crashing into the track bar mount so I plan to use the same closer hole on the steering arm to achieve the angle I am trying to pull. With that said, I need to speed it up from 3.75 turns to 2.5-3. a WJ is a delphi 600 box and is 2.5 turn I need to look at other options to see if I can switch the guts from one to another. I already have the 2.5in double ended ram. Now I just need to order the servo and figure out the box.
So now to today. Cooling issues are 100x better. I can have the AC on pulling a grade in hot weather and it stays cool without the heat soaking.
I have parts….i just have to execute soon.
Remote mount servo.
WJ box I picked up from the junkyard.
I need to put the fast ratio guts of this box into an extra xterra box I have, then depower/free float the piston.
This is a double ended ram, one side is all the way out, other side all the way in. Not a single ended ram like regular ram assist.
I just need a pump, resi, then get to work! I am trying to do this with minimal downtime as I still have to drive it
Windshield is replaced….
I pulled it myself to prove it can be done! 4-5 shops said no…I have to pull the whole cage. I got it out, luckily my now favorite windshield shop got it done.
alright, I kept the Hummer going with its weak steering for about a month and a half because I wanted to keep it moving until the baby came home. My wife gave birth to our daughter last week and to keep the tradition alive of keeping the Hummer involved in all major life events I didn't want it under construction then. It still drives perfectly fine on road and has plenty of power steering in parking lots, it just lacks power offroad.....
Props to my wife for getting in and out of this tall POS after pushing out a baby lol I am glad I was able to bring home both my kids in the Hummer.
Anyways, since it's a quasi DD, I want to tear it down and the timing is now.
My wife got her mom mobile expedition max. We still have her old car that we plan to sell before the end of the year, so I have that as a DD and the F550 if I need it.
So, I am just waiting on the rest of the steering parts and then I will get to town on the Ultra 4500 style steering.
Small update but I need to start thinking about how I want to mount this double ended ram.
With our newborn and just life in general progress has been slow.
I spent weeks 1 hour here, 1 hour there…but it’s coming along.
I tried the ram closer to the axle tube, farther away, more offset from center, less offset, etc.
I finally found a home, it’s closer so it should get hit less but still hung low…so let’s make a pitman arm. Luckily the angle stayed the same so no change in bump steer but going heim gained me like 1/4in
Then I wanted more clearance…so I modified the ram mounts and trimmed them up.
Gained another 1/4in
Then the clevis’s most people use have added height to them which I am fighting so I made this to be low profile.
Now it sits higher then in the previous pic and have maximized every thing I could for clearance.
I still have to test fit a few more things then it’s ram mount welding and reinforcement.
I got the steering mount all done, it has the main plate, then a plate from the bottom of the axle tube to meet at the front of the main plate so it is 1/2in thick there, then the top hat which will transfer a hit to the axle tube vs bending upwards.
Ignore the stacked misalignments and nuts, I need to build spacers for the tie rods.
Then I started tearing into the steering box, what I do not like about the Xterra box is that it is slow steering (about 3.75 turns lock to lock where a stock H3 rack is about 3) I think the SAS is better in every way but the one critique would be the steering. I took WJ box internals (2.75 turn) and put it in the Xterra box, depowered the piston by welding the torsion bar to the input. The box is back together, now I just have to mount the servo and install the pump/resi.
Alright, I got the Hummer running and on the road. The pros, it will run down the highway at 70 mph and not kill anyone. The cons, it does have the shakes at slow speeds/sitting still. This steering setup (depowered box/remote servo) has been known to give the steering wheel the shakes if the mechanical side of things don't match up perfectly with the hydraulic side of things.
A lot has happened since the original post, not all on this thread and ill kind of start from the beginning. When I did a solid axle swap to my H3 back in 2014, I did not consider what I would be doing in 2026. Rightfully so, in 2014 I was blowing up ifs diffs, and I needed to stop blowing up diffs, so steering was an overlooked part. I saw someone use an Xterra box, it fit the frame rail well and I ran with it.
Pros, its outside frame rail to give you a longer drag link. Cons, its rearward facing pitman arm, which causes fitment constraints. While I love the SAS, and think its 1000x better than the factory stuff, if there is one thing I would say is better on the ifs, is the steering angle it pulls.
Over the years I went from coil springs to coilovers, longer track bar, added a sway bar, added air bumps, etc. I added a ton of things that just fit around the box, and to start over with a different box would have had me redoing a **** ton of things. To the point that I probably should cut the front frame off to maximize everything more. At this point I have a 100% stock frame, it isn't even notched in places, and with the restraints of the stock frame it is pretty much maximized.
My last iteration before this one, I ended up with a redhead xterra box that felt tight, and had ram assist for a 1.5in ram. I needed offset heims to not hit the diff cover, which added a dead spot in the steering as it would like to "flop." I could bend a 1.5in .25wall tie rod like a pretzel and probably went through 6-7 of them over the years, I would usually get a year or two out of them but really, I'd get a fresh one, bend it the first trip out and limp it along for a year or two before it was almost unusable and I would have to build another. Finally, I got tired of those tie rods and had one made out of stressproof material because I needed a better material, going up in size would cause fitment issues at full bump. I ran an aluminum tie rod and with the offset ends it actually would deflect driving down the road and cause death wobble! Anyways, so stressproof....I must say that held up SUBSTAINALLY better, in the end it had a slight bow in it but that would last for many many years compared to the regular old DOM one. The cons, it isnt weldable so the ram clamp had to be bolt on and would sometimes want to spin and just be a pain in the ass. Steering effort was never an issue. Just steering angle and steering speed. When I went to 43's I lost even more angle due to the width. Around that time I started to value steering angle and speed more and more. As I ran harder trails, I started to value things I didnt used to care about. While those tires were kickass, at 18in wide, they didnt like to turn far before hitting links, body parts, etc. Going back to a normal width 42, I put an emphasis on steering angle and speed. The con was travel in the box with the OEM pitman arm length. It wasn't pulling much more angle than what I had with the 43s. To solve this, I could make a longer pitman arm, but I couldnt even get 1/2in more length out of the pitman arm before hitting the track bar mount since it was rearward facing and the box is up against the body mount. From what I understand, a longer pitman arm gives more throw/angle and quicker steering. I know a shorter arm on the knuckle does the same. Another con to the xterra box was 3.75 turn steering lock to lock, the steering was slow. It wasnt an issue back in 2014, or on road but the faster I went on tight trails, I couldnt steer fast enough. I know for force, a shorter arm on the knuckle reduces the steering force being put into the tire, I believe the same goes for a longer pitman arm. So I had a long steering arm at the knuckle and a short pitman arm, with ram assist I had plenty of power but it was slow and it limited angle. So I moved the arm in on the knuckle. Speed did pick up but not enough...but I lost a ton of power, I would say more than the speed I picked up. The 1.5in ram wasnt sufficient anymore, and I barely could fit the 1.5in ram yet alone a bigger one, plus my other issues I was tired of. This went on for about 2 years. I was out wheeling a lot, having fun, but I will always remember the thing I struggled with, not what went great. I was just about over it when it came to lack of steering force and speed, then last August, I hurt my steering box just trying to manhandle it. That was the first time I had a catastrophic steering failure on the trail.
It was time for significant change. I was tired of the lack of power, the dead spot from the offset heims, and the ram spinning with the bracket. I need full hydro power, without full hydro. Can full hydro kick ass on road? Yes, it can. It seems most can't get it to work nice on road, but I know it is possible, I have talked to people who say it feels nice on the freeway at 70 but they are few and far between from what I have seen. There is one issue with full hydro you cant overcome, and that is keeping the clock spring happy, the steering wheel can float and drift, which would kill the clockspring and then I would lose the horn, cruise control and a centered wheel. I didnt want that.
So it was time to go down the 4500 steering rabbit hole. Depower the box so it is like a manual box, all it does is handle the mechanical side of steering, the remote mounted servo has less flow constraints of a regular box and handles the hydraulic side of things. I understand that there are a lot of variables and it was best to just follow the recipe known to work but a new box would cause a lot more work, and in the end the same box required a lot more work too, but I didnt find that out until later.
So the plan, sweet servo (not howe modified) because it has worked for trail rigs, an xterra box, with WJ 2.75 turn internals because they are both a part of the delphi 600 platform that can interchange parts, a 2.5in double ended ram like a full hydro setup.. (I ended up using JK 3 turn internals, mechanically advantaged to be 2.75 turn in a Xterra box which consumed a ton of time when the WJ parts didnt end up working out.)
Well the ram would hang down super low due to the drag link and pitman arm combo, if I could get rid of the drag link like full hydro Id have so much room but since I’m keeping it, the trade off I made was a new pitman arm to get the mount to be within a 1/4in of the old tie rod height, and I am a little farther out then the tie rod, the old tie rod was 7 7/8 off the axle tube, to the end of the flat plate I am 8in off the axle tube and the angled part, a tad more.
So, will it work better? I don’t know. Is the power better? I dont know....I assume a 2.5in DE ram with a 1750 psi pump has more power then a 1.5in SE ram, and a box.
Will the clearance be worse? Idk, I mean I hit the **** out of the tie rod for over a decade, now the 2 tie rods for the ram is higher, but the ram mount is ever so slightly lower and I’m not sure if it’s more slippery or not.
The 2.75ish turn box is much better and quicker.
The shakes suck, but I’ll work on that. The .220 bar is stiff as hell, but I can change that too.
Enough rambling...pics.
Driving into a lone rock, to make sure it doesnt fall off....or bend.
Driving down the highway...
The shakes when parked.
(the video wont load....I will link it to youtube later)
Lastly, here is the "sentimental part," is the steering where I want it to be right now? No....but it is safely running and driving and that matters more than ever. The last 15 years I have wheeled a lot, I have driven all the way to Maine to go wheeling when living in CA. I probably spent 20+ weeks of vacation for week long trips in the last 10 years. I have gone wheeling monthly or close to it for many years but the last 8 months have been rough. I broke 8 months ago and havent wheeled since. That is the longest time I have gone without wheeling since I started wheeling and it is my therapy and fun. Between our 2nd child being born in those 8 months, my wife dealing with some postpartum this time, new job, 2 vacation days since May, and much more random ****, this has been a challenging 8 months for me...Yes, there's always someone who has it worse, someone dealing with cancer and the foreclosure of their house, or some bad bad ****, and this wasnt bad, nor am I trying to make it sound bad, it was just a challenge, and when life is a challenge, bailing out for 1/2 day to go wheeling gets rid of those issues temporarily and I didnt have that. So driving home I was grinning ear to ear just to be driving my H3, listening to the same music I listened to road tripping to my first moab trip 15 years ago. It felt like life is getting back to normal.
Normally I would be asking myself, will this work? Will I have to cut it off and redo it all because it sucks? Now I am telling myself, if it sucks that bad, I have a cut off wheel, I can start over....begrudgingly.
So I plan to just wheel for a while, while dialing in the steering. It does need adjusting but it is wheelable. Then it will be time to do some coilover mount changes, because that was a project I would have done differently in hindsight. I didnt want to go through the floor but the ground clearance has pissed me off enough, I am now willing to do that.
