He's got a Rancho lift kit so the CVs are still level; he's in good shape. You are right on target if he'd done this just with the torsion bars.too much and not good for CV's anyway !
Crank your T bars at front, max 23.5", from Wheel hub center to Fender bottom and put 1.25 or 2" longer shekels at the rear . Going over 23.5 " at front can serious affect those CV's
Yeah, the ranch leaf springs are totally shot, sags a ton in the back. So much that if I fill the gas tank to full it smells horribly of gas, coughs, sputters and stalls until I burn some off. I think it’s sitting so low in the back that at full it runs back into the fill pipe and jacks with the evap and vents.I say, NO LIFT In the rear whatsoever!
Not needed and who wants a rake anyways?!?!?
Not leaking anywhere, but you can smell gasoline fumes. It seems like when you fill it all the way up it’s filling up too far into the Phil tube. I believe it might be covering the vent to running to the EAP system as well. Only does it when filling it completely full until the pump handle hit the auto stop.If you have leaking gas from filling it up, then you have a bigger issue than sagging springs.
Looking at my pics I’m hitting right at 26” in the front and 23-23.5 in back. When I jacked up the rear for the pics the front dipped down about 1/2”.The front should sit at about 26.0-26.5" hub center to fender on the Rancho kit so rear should be at that too or slightly higher.
Now you tell me!I would do a SOA before the re-arch. Works good with the Rancho kit.
nope. I stamped them for DS front and PS front so I’d be sure. I suppose he could have packed the rest of the spring pack backwards. But the top wedge/spacer is correct too with the Fat end forward. Hopefully Ranch comes through with the specs like they did for the bushings!not on backwards?
I suppose the axle shifting is a possibility. However, when I dropped the leaf springs out, the axle didn’t really seem to move at all. I did not disconnect the swaybar links. So that’s generally holding it in position. I’m not sure if that makes any difference or not.Are you sure that your axle hasn't shifted?
Yep, both lead springs are out. The only thing holding the diff in is the rear sway-bar links. Perhaps I should have bolted them up to the diff first then persuaded the bushings into place. That might be the play.you have both sides disconnected (ubolts loose and leafs not attached to the diff)?
Tires off the ground?
That way you can shift the diff to the right spot for the dowels to line up.
