Works like a charm in an H1.
X2. I can't think of a situation I couldn't BTM my way out of
what I always did was stay off the brake, give it a little throttle, then wait and give the traction control a chance to kick in. It took a bit of getting used to, it's not instant, but if you stay off the brakes and give it a chance it does work.
BTM is an "open diff" technique. It causes the spiders gears to alternate from right-to-left dominance, and it works on any open-diffed rig, (done it many times with open-diffed Jeeps). It honestly doesn't do much by itself. But on the H3...the puter will step-in and work with BTM to take full advantage of moving around the power to the wheel that needs it. The puter needs to sense wheels spinning at different speeds to do anything. BTM simply uses the brakes to fake the puter into searching for traction at one of the corners. Without using the brakes...the system still works in the same way. The only difference is that you have to apply more throttle and induce wheelspin for the puter to sense it. And as we all know...that's not healthy for your H3. So BTM is a way to induce traction control at a relatively low speed, without mashing the throttle and spinning the hell out of the wheels. Simply put...it allows you to crawl slowly and still use the TCS, something that is unique and special about late model TC-equipped rigs.
I don't think you are giving TCS the credit it deserves.
There will always be a place in my heart for a 6000 rpm assault up a rutted-out ravine.
You don't have to mash the throttle and spin the hell out of the wheels to get it to kick in. It works just fine with a nice easy barely spinning wheel.
I use my front locker sparingly. but there are times that it makes very difficult climbs much easier. I don't worry about getting a wheel in the air as long as I don't let it spin. Spinning is what causes breakage.
Where the front locker helps the most is on those steep inclines where vehicles have created holes in a diagonal pattern so that you only have two wheels on the ground most of the time. Without a front locker you need momentum, but with the front locker you can crawl right up. Here is an example of Cbetts at Hauser geode beds.
