I need to know how to take apart the rear seat quick latch mechanism?
Happy Hummer
Wisconsin
Please... help
This is really got me stumped. How does the rear seat latch quick release come out of the foam?
Trying to change the fabric to leather. It just seems crazy that after an hour couldn't remove it.
On the underside pic (Pic 4) are those black items screws or Christmas Tree/friction hold? If they are just friction hold it seems like you would *carefully* push them up or pry from the top, a little on each side at a time, to separate the black plastic from the metal piece. Also, is that a small clip at the edge of the black rectangle where the rod is located? Maybe it's hold that clip and pry/push to separate the plastic from the metal.
Happy Hummer
Wisconsin
I wanted to provide some insight gained from hours of work and cuts, bleeding, bruises etc.. 😆.
This truly had me stumped and I wasn't sure it could actually come apart without true carnage. After a lot of head scratching last night pondered, meditated today while working (not on this but actually working to make a living lol). Anyways a thought struck me, what if the whole contraption is carefully seperated from the foam core? That's actually how it really works! The fabric, release handle/paddle, bezel, metal bucket-ish looking thing all gently pry through the foam. I've included some pic's of the stuff.
I can tell ya this was a difficult task changing the back uppers (seat backs rear) from fabric to leather. There are a tremendous amount of hidden Christmas trees and snaps, screws and wierd funky things to deal with. About 10 hours just to swap fabric for leather. May be 3 more for removing the whole assembly from H3 and reinstall the whole contraption. Any way pic's.
After you remove the complete deal when you flip it over you'll see to tangs. Depress those with a flat blade screw driver and gently jiggle the paddle/handle to help the bezel free it's self from the underlying structure. This is shown in the pic's. There is a different kind of thing opposite of the two tangs which slot behind the paddle into the hinge area. The material is sandwiched between this section. Reverse this precisely to put it back together. This is way harder than it sounds.
Happy Hummer
Wisconsin
Wanted to update about rear seat uppers. Pic's...!!!
This is coming along nicely! Kind of excited about the overall vibe.
Nice work! Sorry to be late to the game on a response. Leather is tricky to swap over on the H3. I believe they inject the foam around the frame if I remember correctly
