:thumbs:
Yep, you can fit 37's with the Rancho 4 in. lift. There was a member that ran 37's with the stock drive train, not sure how long that lasted. :roll:
Bebe has 38's with a custom lift and a new beefer front differential. Recon has 37's I think, again with a custom lift and a solid front axle.
Besides the added stress to the front differential that can barely handle 35's, 37's weigh a lot more than 35's, so your inline 5 is going to struggle even more to get you up to speed. Also the front diff cannot be regeared above the adventure package 4.56 gears, otherwise you could change gears to help your engine cope with the bigger tires.
