BBYHUMR 06 Re-build
BBYHUMR
Well progress has been made today, however I don’t have any photos to go along with the update unfortunately.
Motor mounts fully installed and tightened. Fought with the passenger side motor mount bolt for a bit longer but finally got it inserted. Would have been easier to either pull the AC compressor or install the body side mount then bolt it to the motor but oh well, unfortunately there isn’t a “how to” for these swaps so you just have to live and learn.
Got the flex plate to torque converter bolted together and the remaining transmission bolts and starter re-installed.
Got the harness all connected minus the battery connections and the BCM plug since I still need to finish running my OBD2 wires, and loom the wiring.
Realized I didn’t swap the transmission mount from the 06 to the Alpha so I got that swapped over (they’re the same but the Alpha mount was completely collapsed).
Ran the fuel lines just to realize they won’t work. The connections are both pointing in the same direction (motor and body side), and twisting the engine side of the fuel line to get it to connect causes kinks in the braided portion of the line so I need to figure out a solution, but will probably use a combination of the old fuel lines and the new (alpha) fuel lines with a few inches of fuel line to connect them. I’m by no means devastated by this as the lines were showing some rust and I was extremely surprised GM routed the fuel lines like they did around the exhaust. Just seems like a lawsuit waiting to happen. I will try to route the fuel lines high up on the floor with some heat wrap around the connectors.
Started running the transmission cooler lines (yes I should have done this while the motor was out) but realized the oil filter drain funnel thing on the front crossmember is in the way since I’m using the Alpha power steering cooler so I need to pop that off. It won’t be used anymore since the V8 filter and drain plug are both at the rear of the engine.
Tomorrow I will finish getting the transmission lines run and hopefully resolve the fuel line issue. After that it’s a matter of dropping in the rad & condenser, running coolant hoses, changing/filling fluids, finish wiring the OBD2 port, then fingers crossed it doesn’t catch on fire when sending power to everything.
BBYHUMR
Back to updates with pictures!
Tackled the fuel lines today.
Like my previous post the Alpha fuel lines won’t work without kinking the braided portion. You can kind of see in the picture below the angles of the hard lines when they’re attached to the motor
The body side of the Alpha lines run forward rather than a direct 90* bend at the frame rail.
Luckily I still had my old lines from my i5 so I pulled those off lopped them down to around 20” and laid them up to figure out a way to join the two sets together.
Surprisingly enough my first cut was actually pretty accurate. I probably could have cut them just after the bend but the rubber hose allows the angle necessary to wrap around the body.
I cut the Alpha lines just after the transmission bolt bracket, you can see my tape “guide”
This allowed the pipes to line up pretty closely. I ended up cutting another couple inches away from the i5 vent line to give a bit more of a “sweeping” curve for the rubber rather than a sharp 45*
This morning I had picked up 2 feet of 5/16” FUEL INJECTION hose. Make sure it’s fuel injection hose, otherwise it will split or erode within a month or two. Ran about $10 a foot so it’s certainly not the cheapest stuff. I used a little over a foot of it along with 8 hose clamps and a small flare at each end of the hard line.
Then I wrapped them up with some heat wrap around the rubber portion of the hose and extended the wrap a bit to hopefully help with the exhaust temp.
Very difficult to show but the lines run along the top of the transmission similar to how the old lines were run with roughly an extra 4-5” of clearance from the exhaust over the stock routing.
After I was happy with that I moved on with the reassembly.
Got the transmission lines run and connected. Found this was easier than I was planning on it being after breaking off the drain funnel thing off the front cross member.
Got the radiator/condenser installed along with the fan shroud.
Got all the AC lines run and connected to their components.
Got coolant hoses all ran and connected.
The only reason I’m okay with connecting all the hoses is because I tested the motor before I pulled it. If there are issues it will be in the wiring which is all pretty easily accessible with the hoses and what not installed.
Started working on my intake system but realized I ordered the wrong elbow size so I need to order another elbow. I will need to cut roughly 2” off the aluminum tubing but I had planned on it needing some trimming. I did need to lop off the stud on the passenger fender since the box wouldn’t line up with it (my i5 box was broken) so I’m using the Alpha box. I’m happy to report everything else lines up perfectly and clears the shroud as intended. I will likely eventually drill a hole and throw a stud in the missing location since the box kind of “bounces” in its location.
After this I kind of ran out of steam. So I threw on the engine cover and snapped one last picture as a little motivation for myself before shutting the doors for the evening
BBYHUMR
Another productive day!
Set myself up to finish the wiring today.
Finished up the BCM plug and loomed everything up. Then I moved over to the driver side to get a couple loose wires tied up over there.
Jumped underneath the truck and tried snaking the exhaust through. After about 15 minutes with zero luck I chopped the exhaust off just in front of the secondary cat. I wasn’t planning on using the secondary cat anyways so no harm no foul. After I got both sides installed I threw the differential crossmember back in place along with the driveshafts.
At this point I was looking everything over to see what else I needed to do before trying a start up and realized the only other thing that needed work was the intake and filling up fluids, so I decided it was time and jumped inside.
Turned the key, and waited for the fuel pump to prime the lines, shut the key off and turned it back on again to re-prime then left the key on while looking underneath to make sure I didn’t see any fuel leaks from my line modification. My big concern was the exhaust is cut just in front of the fuel lines and obviously fire + fuel outside of an engine is no bueno. After about 5 minutes of casually watching and not seeing any fluid I jumped back in and turned the key. The motor cranked for about 2 seconds before firing right up!
I let it sit and idle (poorly) for about 30 seconds before jumping back inside to shut it off. Found some error messages for “reduced power” and “traction control system failed” along with the normal “change engine oil” message. I expected some error messages so this was not of any worry, but what was making me scratch my head was how poorly the engine ran, it had a bad misfire like a dead cylinder. Since I tested the motor before pulling it from the ‘08 I knew it must have been something simple. Spent all of 30 seconds looking things over before I found a plug wire had gotten pulled off the ignition coil on number 3. Plugged it back in, started it back up and ran smooth as silk.
I filled up the radiator with about 1.5 gallons of coolant with the engine running to burp the system. Temp rose to just barely above the half way mark, continued filling up the radiator after the system burped itself and dumped the remaining half gallon or so I had into the overflow tank.
All in all the engine ran for roughly 10-15 minutes while burning the oil off the exhaust manifolds. I sent a message to Jamie regarding the error messages I was getting and he gave me a couple wires to swap so I’ll try that tomorrow.
After making sure I had no fluids dripping I spent a bit of time working on my intake system since my new elbow showed up today. Got everything lined up and it clears the radiator fan by about 1/4”
Still need to run the 3/8” tubing for the vent and drill a hole in the pipe to accept the fitting but it looks good and everything clears. I think black hose clamps would have been a better look but oh well, can’t complain for $30 worth of parts from Amazon.
BBYHUMR
More progress!
Swapped a couple pedal signal wires around and all the error messages went away! Plugged in my code reader and only had a couple codes for crank positioning needing re-learn which is no big deal.
She idles nice and smooth with great throttle response.
Decided to enjoy the nice day and pull her out of the garage to finish up the intake.
Pulled the intake pipe off and plastic welded the insert in for the PCV and cut the vent hose to length.
Finally took her for a drive to pick up the kiddo from church and hit sonic for drinks. Drove very well, obnoxiously loud since there’s no exhaust, but ran good with one exception. The shift cable keeps popping off the linkage. I need to find a snap washer in my bucket-o-bolts to keep the cable attached.
After that it’s just a matter of throwing the hood on, cranking the torsion bars back up to normal (I lowered them when I was trying to stab the motor), and hanging up the skid plates before I take the 45 minute drive to the exhaust shop to have some pipes and muffler put on it. Probably won’t have it finished this week off but it sure was nice to drive it again!
BBYHUMR
Got the wiring all buttoned up, coolant and washer tanks secured, the truck lifted back to around 23”, the battery connected with my shut off switch, partially charged the A/C (need one more can), and got the hood put back on. Also tinkered with the shift linkage and found I didn’t lock it in place on the linkage so it had extra slop causing it to come off the linkage when switching between gears. I still threw on a little lock washer just for added security.
Tomorrow will be changing fluids and hanging the skid plates. Exhaust shop scheduled for Monday!
BBYHUMR
Got the oil changed today and hung the skid plates under the truck. I realized I forgot to keep the front bumper bar for the front skid plate so I have to do without it unfortunately.
I started pulling the seats and carpet out of the Alpha since mine have seen better days. I’ll end up using the front seats from the Alpha in my ‘06 and keep the rear seat in place since it’s still in good shape. I need to sound deaden the floor before I install the replacement carpet so that will have to be done another day.
I also pulled the windshield moldings off the Alpha since again, mine have seen better days only to realize my roof moldings are missing the piece that holds them down against the windshield. I’ll see if I can save the ones off the Alpha since these hugged the glass pretty well.
BBYHUMR
Well, a little behind schedule but the H3 is back at my place now!
Had to wait a few extra days to get a ride from my place to the ex’s where the truck has been sitting (about 45 minutes one way).
Drove great all the way, and boy what a difference with the 3 extra cylinders when trying to get on the highway! Don’t get me wrong, the H3 is still a fat pig, but at least now when you’re trying to get across a 2 way stop you don’t have to worry about making it across an intersection in time!
Ended up wrapping the fuel line connector above the exhaust cut off with some heat tape until I can get it over to the exhaust shop to have the duals run, and get some exhaust wrap on the pipe. Might see if I can get it over to the exhaust shop tomorrow to have them knock it out. Going with a Flowmaster 40 series with dual black tips
BBYHUMR
Exhaust is 95% finished. The tips I had the shop order didn’t end up showing up but they ran the piping - dual in into flowmaster 40 series with dual straight out at the bumper. 3.5” black tips will hopefully arrive within the next day or two and I’ll swing back by for them to slap them in. Sound is much more manageable than the essentially open headers it was running before but still has a good growl while driving.
